Type name for a small USB connector?
N_Cook
Smaller than the smallest USB connector I've seen up to now, on compact
cameras etc.
The connector must pass through 5.8 x 3mm hole in casing. Not trapezoid in
cross-section, but rectangular with 2 chamfered corners on a long side
Meat Plow
cameras etc.
in cross-section, but rectangular with 2 chamfered corners on a long
side
Appears by description a mini 6 pin USB cable. My Casio EX-Z1050 uses
one.
N_Cook
one.
As recessed in its difficult to see as so small , perhaps 8 ruts with 5 or 6
conductors. But smaller than the USB mini AB type. Under 30x as end on can
read 2.2 for the electrical type of USB but still not found a generic name
Meat Plow
or 6 conductors. But smaller than the USB mini AB type. Under 30x as end
on can read 2.2 for the electrical type of USB but still not found a
generic name
This Casio plug is actually 12 conductor and is wider than a 4 pin mini.
I have another camera that uses a much smaller connector maybe 30%
smaller than a 4 pin mini. It's almost square with two rounded edges
to prevent improper insertion. They seem pretty popular. as i have a
couple of them in the cable bin.
N_Cook
isw said:
Although those connectors may carry USB signals, I think they're not
always "USB connectors"; some of the ones on cameras also carry
audio/video signals, and they don't mate with similar-appearing USB
connectors.
Isaac
That makes sense but there is a standard USB symbol at this camera connector
N_Cook
cameras etc.
My Konica/Minolta DiMage E 500 camera uses such a connector. The tip
measures 0.082" by 0.193", about 2.1mm by 4.9 mm.
It has five gold fingers (probably two are power-ground) with
asymmetric placement (1 x x x 1 1 1 1 ).
As for a name, or vendor, I dunno.
Sounds like the critter
I'll go with the name micro USB . But thinking about it later, I'm currently
removing the SD card and reading via a different camera and larger USB. Long
term reliability of repeatedly using the large SD contacts must be better
than using this micro USB with contacts that are so fine they are on the
point of non-resolability of my eyesight.
