pidy said:
It means you just need to configure one of the AVR as a slave and
the other as a master. Should be pretty easy.
I suggest you setup the master first and than test it with a known working
slave, perhaps eeprom. Once that is working setup the other AVR as a slave
and work on it until the entire system is working.
It may be helpful to have storage scope or logic analyzer to check the bus,
if you get stuck.
C source for slave and master is available from atmel or avrfreaks, its the asm
code that's a bit harder to find from my experience (but it exists as well).
http://www.atmel.com/dyn/products/app_notes.asp?family_id=607
check avr310,avr311 and others
SioL
