Hi everyone, I'm new here and I have an exciting challenge on my hands.
I have an ozone generator from China, will be used for water disinfection. Its rated at generating 10 grams of ozone per hour. I would like to reduce this by 10 or 20 fold (0.5 - 1 gram/hour).
http://www.banggood.com/220V-10g-Oz...ble-Sheet-for-Chemical-Factory-p-1070789.html
So there it all is. I can see the mains coming into a bridge, then through a LC circuit creating the high frequency for the primary flyback windings.
My solution:
I was thinking about using a resistor, calculated by ohms law in series with the corona discharge plates to reduce the overall current going into the circuit. With the information; 3.5kv @ 50w provided by the manufacturer.
My question:
Will this work? Can you think of a better method?
The goal:
Reduce both noise & ozone output.
Thanks in advance
Grazj
This is the internal circuit at a glance:Ozone Output: 10g
Input Voltage: AC 220V
High Voltage: 3.1kv-3.5kv
Power Consumption: 50W
Gas Feeding: Dry Air or Oxygen
Ozone Generating Method: Corona Discharge
Cooling Method: Ambient Air Cooling
My solution:
My question:
The goal:
Thanks in advance
Grazj
