TV PSU Repair - Diode replacement
Hi all
Got on great with my other TV repair that you guys helped with with the blown caps, many thanks for that.
So I then remembered, we had a TV that just stopped working one day and I thought, what the hell, its probably something easy again.
Whipped the back cover off was expecting the caps to be gone again, not this time. But I do know what the problem is.
The TV is a Digihome 23" LCD and inside it the PSU is a Vestel 17PW80 v2. I've included a picture with a circle around the bad diodes which are causing the dead TV.
How I came to my diagnosis was I looked on ebay for the PSU and found loads of ads offering a repair kit for this model, all picturing these diodes. I then looked up how to test diodes with my multimeter, and tested all diodes on the board starting with those three and the three circled all appear to be bad to me.
My diode test on my meter reads 0v in both directions, this I'm lead to believe is open circuit and so...bad. I have read that the test can be different when not in circuit so I should remove them all and test individually off the board?
Also, going by their markings, they look like they say sb5100 2099. I've also read that Vestel designed these bad and the 5V rating on them is un-necessary so I can get away with 3A? Reason being, Maplin don't stock these diodes but 3A ones seem to be possible, so can I use an alternative that Maplin sell?
Any help muchly appreciated.
Hi all
A pic of the board
Hi Griffinballs,
Welcome back.
First, you don't check diodes with V. You use the continuity or Diode function on the meter.
The SB5100 diode is a shottky diode. 5A 100v or similar.
Martin
Hi Martin
Thanks, yeah sorry, I knew how to test the diode with the right function, just didn't know how to write my reading lol so chucked v after it, lol.
Quick update, googled about a bit and found that the favourite is usually the bottom diode. So I desoldered one leg, retested the diodes, sure enough. Thats my only bad one too.
Put the TV back together (only to test) and sure enough, power led is now back on. Didn't start it up, just plugged in to check it worked.
So now I need to replace that bottom diode.
As you say, its a shottky 5A 100V. Worst case I'll order it off ebay but Maplin are open tomorrow, if I can find a suitable replacement on their site, then I can get it straight away.
Is this one any good? http://www.maplin.co.uk/p/1n5401-3a-silicon-rectifier-ql82d
Its not a shottky, but since I know sweet FA really about electronics, I don't know if thats any good or not? Its a 3A, not 5 but I read on another thread about the PSU that that part doesn't really matter in this application. The thread in question is here http://www.badcaps.net/forum/showthread.php?t=28778
Thanks again for your help Martin, I'm really enjoying this new hobby. Gonna start having a look for some half decent dead TV's on gumtree, see if I can get a nice cheap upgrade :D
To be honest, if a shottky diode was in the original design, there could be other reasons.
Faster switching is one reason.
The other is lower Vf, forward voltage.
It might work perfectly well, but I would personally put a direct replacement.
Martin
I really like people like you!!!
You get stuck in and ask the right questions.
Cudos to you. And happy electronic tinkering.
Just be careful playing with TV's..High Voltage, Don't become complacent.
Martin
