With great help from the forum, I'm creating a device that will tap the speaker wire from a bridged car head unit. The original post can be found at https://www.electronicspoint.com/threads/modifying-agc-circuit.282370/
The device should be turned on when the head unit is turned on. Since I'm already interfacing the speaker wire, I was thinking that I could detect the 6V DC bias and turn on my device when this is present. After a lot of searching and reading I came across a high-side circuit that I think will fit:
With my VERY limited analog circuit experience, again I ask you for help:
1. Will this circuit work?
2. Could you please help me find some components to use for Q1, Q2 and D1? I'm really getting lost in the specifications here.. (Voltage - Collector Emitter Breakdown, Vce Saturation (Max) @ Ib, Ic, Current - Collector Cutoff, DC Current Gain (hFE) (Min) @ Ic etc.)
