Tumble dryer power switch problem
Mike B
It's a Westinghouse LD505e
As from today I have to hold the power switch in all the time otherwise it
switches itself off. I used to be able to just press once for on, and again for
off. Other than that it works fine.
The power switch is non-latching so there's no visual indication of on/off other
than the LEDs and beeper.
Here's some pics.
Power switch is the brown thing on the right.
http://members.iinet.net.au/~mbuckler/tumble-dryer/pcb-right-and-power-switch.jpg
Reverse side showing power switch on left and control relays.
http://members.iinet.net.au/~mbuckler/tumble-dryer/power-switch.jpg
Transformer
http://members.iinet.net.au/~mbuckler/tumble-dryer/transformer.jpg
PCB middle
http://members.iinet.net.au/~mbuckler/tumble-dryer/pcb-middle.jpg
PCB left
http://members.iinet.net.au/~mbuckler/tumble-dryer/pcb-left.jpg
Does anyone have an idea of how to diagnose this?
Mike
Me2
HI Mike,
The power switch looks like it would be a latching type,
It has High current wires attached i.e. its not small signal type like would
be used to trigger relays/ electronics.
See if you can get hold of a new one and compare it.
If your sure its not that, check the door switch.
Best luck, don't kill your self, or burn the house down.
Allan
Dan
again for
other
Here's some pics.
Transformer
PCB middle
PCB left
Diagnose what? it must be latching and its fucked
Mike B
HI Mike,
Allan
Pulled the switch apart (it turned out to be a latching type) and cleaned it.
I guess fluff or something got inside..
I was expecting it to be like the front panel switch in a computer which simply
carries a logic signal.
It's all working now.
Mike
