Tube PWM... I finally got around to it
Tim Wescott
http://webpages.charter.net/dawill/tmoranwms/Elec_Compound.html
The top part is off topic; scroll down to around the bottom for the circuit
and description.
I haven't done the output stage yet; it's next.
Tim
You will find, I think, some pretty significant nonlinearities in the
output stage due to discontinuous conduction.
But please, don't let that stop you, it's an interesting notion.
Tim Wescott
Control systems and communications consulting
http://www.wescottdesign.com
Need to learn how to apply control theory in your embedded system?
"Applied Control Theory for Embedded Systems" by Tim Wescott
Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
Tim Shoppa
and description.
Tim
Very interesting. One note based on me using those Heath scopes
decades ago: the little nubs you are seeing are probably related to
the scope's triggering circuitry either intentionally or
unintentionally screwing up the horizontal sweep. (It is an injection-
locked oscillator after all). IIRC if you move the trigger sensitivity
up and down then the nubs move too. I never knew if this was
intentional or not (after all many of the expensive scopes had an
"intensify trigger point" option, maybe Heath had a cheaper way of
doing it!)
Tim.
