I have one of these rear-projection tvs. It seems the antifreeze coolant has
left some grime on the inner lens, murking up the display horribly on at least
two tubes.
The lens appears to be glue-sealed to the tube, with screws to add small
quantities of coolant. It needs to somehow be removed so I can clean off the
grime and reseal it... I don't want to try to pry it off and risk damaging the
lens.
Can someone suggest a solution? Is this something I can do myself with limited
tools or should I just send off to a service bureau?
FeSS
two tubes.
lens.
FeSS
