I have a bunch of 74107 JK flip flop chips which require 5V vcc. I also use 5V for the logic inputs. The output, however, is 3-2 volts, so if I try to link one gate's output to another's input, the second gate doesn't register the input signal as a logic "1". The datasheet seems to claim that the output voltage can be 0 to vcc. Why isn't it outputting a high enough voltage? How do I fix it? Did I fry the chip a long time ago? Thanks!
EDIT:
Does this happen when not enough (or too much) current is applied?
--Josh
EDIT:
--Josh
