I have some 12v D.C. LED lights in my boat, that are on a dimmer. When I run the Freshwater Pump, the lights all pulsate with the pump motor.
The lights, dimmer and pump all return ground to the same buss bar. The lights are all running at less than 10a and the fresh water pump is running at less than 15a.
Can I use a capacitor to prevent the lights from pulsating? If so, what size & type would I use. Also, would running the return ground from the pump to the battery, which is 30 feet away in the engine room solve the problem?
Would appreciate any help on this
