A bit of background, so as you know who/what you are dealing with. ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm no electronics expert, but I was a hobbyist in my teens. My test and repair tool-set comprises a digital multimeter and a soldering iron.
I have an induction hob that has just stopped heating (the digital display works fine, just no power to the inductors). Before replacing, or throwing away I thought Id take a quick look for likely items that may have failed.
I can see that the left and right pairs of heating inductors separate power circuits which seem to be controlled by a common control board. As none of the rings on either side work I have assumed that this common controller is the issue.
The only mechanical component on this board is a relay, which I figured a likely point of failure and I have got a replacement for a couple of £ and installed it.
Before refitting the board I noticed the component in the attached photo. I'm assuming this to be a fuse? The only markings on it are those shown and I can't encourage Google to provide any help. My multimeter is showing it as open circuit.
Could anyone conform that this is a fuse and if so what, or how I might be able to determine the specifications of it?
Thank you for any assistance you can provide.
![Fuse.jpg Fuse.jpg](https://makerv2.webteractive.co/forums/data/attachments/22/22595-58721379b230d582d008d09e8cb50707.jpg)
