I'm trying to get a laser sensor to trigger a JQC-3FF-S-Z relay. The sensor is this little guy:
It can be found by googling "Icstation 5V Light Sensor Module Receive".
The JQC-3FF-S-Z relay can be also be easily googled:
I have it wired thusly per my understanding of schematics found for both the units:
sensor VCC and relay DC+ connected to power supply 5v positive
sensor GND and relay DC- connected to power supply 5v negative
sensor OUT connected to relay IN
relay jumper is set to honor a high signal (5v in this case)
relay secondary COM and NO are used to complete a 120v circuit upon activation
For the power supply I am using a USB 3.0 5vdc 2.1 amp cell phone charger.
With just the relay connected (DC+ and DC- to power supply) I can trigger the relay by jumpering DC+ and IN and run the 120v circuit.
With all connections as above except the sensor OUT-relay IN connection, 5v+ appears at sensor OUT when the sensor is hit with a red laser. I assumed this would be sufficient to trigger the coil when wired to relay IN.
With all connections as above, when the sensor is lasered the relay's secondary (triggered) led goes on but the coil does not activate. (I should note that both the sensor and my version of the relay have leds that do turn on when the units are powered on. The relay also has the second led that goes on when a signal appears at IN.
Am I misunderstanding how this should work? Does the sensor not produce enough current to power the coil? I have five each of the sensors and relays and have tried several combinations with no success, so I don't think it's a bad unit...unless my wiring is breaking them haha.
Though I have messed around with this sort of thing now and then my whole life, I'm not an electronics expert by any means, and would be grateful for any assistance.
