Peter S. May
I'm trying to rebuild parts of the Microchip PICDEM FS USB board
schematic partly as an experiment but mostly as a learning experience.
There's a part of the circuit that appears to allow the device to
auto-select between USB bus power and wall-brick power, that looks sort
of like this:
NDS352P 1N5817
[VBUS>---+--+--[S G D]---->|--+-[+5V>
[VREG>---|--|-----|------->|--+
\ | \ 1N5817
100k / =.1uF / 33k
+--+-----+--| GND
From what I read, NDS352P is a P-channel MOSFET. I also can't seem to
locate this part on Allied, and didn't have any better luck with a
couple of cross-references.
I'm thinking that this is an opportunity for me to learn about MOSFETs
since I've never used one before. I only recently really learned about
BJTs, and can only really keep it straight because, in general, only a
small selection of the figures are relevant: hFE (the current gain Ib
to Ic), which isn't crucial when used as a switch instead of an analog
amplifier, Vce (voltage drop collector to emitter, i.e., how much less
than Vcc is dropped across the output load), and max Ic (how much
current can be passed through the load).
What are the important (analogous?) figures for a MOSFET? What features
should I be looking for in a replacement for NDS352P?
PSM
of like this:
NDS352P 1N5817
\ | \ 1N5817
100k / =.1uF / 33k
+--+-----+--| GND
PSM
