I'm troubleshooting this circuit which powers a dc-dc controller. It's on a HP dv7 motherboard with AMD chipset.
I believe there is a short and I'm unsure whether it is a downstream component (like a bad chip) or a problem with this controller. I found the specs for this controller: http://www.datasheet-pdf.com/datasheet/O2MicroInternational/697173/OZ811.pdf.html
I have verified the following, with the computer powered off, and power adapter plugged in:
Question 1: without powering the computer, should LDR be showing any voltage at all? It drives the gate for the low side. It makes the MOSFETs PQ66 and PQ73 seem shorted as with the power adapter plugged in, the gates are energized. Also, these two MOSFETs are getting hotter than they should when the circuit is energized. The coil right after it (on the other side of the board) gets hot as well and I can feel it through the board.
Question 2: why is LX negative? It is supposed to power the VGA core circuit after this and obviously is not the proper voltage. I could understand a short downstream causing problems later...but why would it be negative voltage? I could not figure out what voltage it should be.
Circuit may be sensing overload and not allowing a turn-back-on scenario. I have to wait awhile and then it will turn on again, not boot, and then totally turn off after 15 seconds or so.
I have checked all components downstream and removed many and put them back on. Seems like a short in the chip. BUT - it turned on yesterday and was just fine. If it does turn on, the computer is fine unless I try to restart it - it won't even POST. So, it appears to be having voltage issues, and this controller - how do I know if it's working right? What do I check?
Thanks!
- 19.2v is supplying the pin 2 VIN
- 5.2v is supplying both pins 5 and 16
- BST on pin 8 is showing 5.2v
- LDR on pin 7 is showing 5.2v
- nothing on HDR and nothing on LX
- All caps and resistors seem fine
Thanks!
