Hello!,
Im trying to figure out what the problem is with a set of gauges I have, to make it clearer what im working with they are temp/oil/battery/fuel gauges and also a tacho.
http://thumbs2.ebaystatic.com/d/l225/m/mzhTgpZlKyTYn9vnQA8jnOg.jpg
Im trying to get the oil and temp gauges working however they do not respond, I have grounded them and they go up and down so I believe they work.
The tacho works but the needle is way to low, it would be at 500rpm when it should be like 1500rpm.
I have been told that apparently the voltage is regulated from 12v to 5v for the gauges, I have used a multimeter to check this and currently i get 12v to the gauges.
I have attached a few pics to show this supposed regulator, it is an old school piece of metal I think.
Lastly, the fuel gauge has been working to some degree, currently it goes straight to max, like off the chart and I think it was working backwards, the more full the tank, the closer it was to 'low tank' on the gauge. Im not 100% sure if thats the way I remember it tho.
so my question is how do I tell what voltage a regulator is? im not sure if its 5v that is supposed to go around this gauge.
all help greatly appreciated!
