Brick
Hello,
I just purchased a baseline flash microcontroller programmer for
programming 10f series pics. Unfortunately I'm having a difficult time
getting it to work.
The software recognizes the programmer fine and everything seems to
work, but when I try to read a chip every memory address reads as 0. If
I write to a chip it will seem to work and then fail on the verify
(which just means that it is reading all 0's again). At first I thought
that maybe I had fried the chip so I tried using a different one and
was very, very careful about static discharge. Same thing. Then I
thought that maybe I made a mistake when I made the pdip adapter, but
I've checked it over several times with the datasheet. I even checked
to make sure that all of the connections were well connected to the
chip's pins.
I'm lost about what to do now. I can't find any relevant documentation
on the programmer and I'm out of ideas. If anyone has anything that
might steer me in the right direction I would be very thankful.
Brick
getting it to work.
chip's pins.
Brick
