Hello,
I am trying to get an LM567 to respond to an output from a 555 timer in the astable mode. The R1 and C1 for the LM567 are 10KHz and 6.1uF. The other components are the same as on the data sheet in the drawing with the multiple tome decoders (I'm just using one of these tone decoder circuits). I may have damages the LM567 because the voltage I measured on the input was about 8VRMS which would give a peak voltage higher than the max tolerable on that pin. I lowered the voltage with a voltage divider but there was still 6 VRMS on the input although the divider output was 1VRMS. I don't know why. I don't have a scope. The LM567 output doesn't go low for any frequency in the range the 555 was set for. I will try to provide a schematic, but I need a little more time. I don't have a working scanner or cad software.
George
George
