Trouble with ADA2200 in Multisim
I am trying to simulate ADA2200 in Multisim. The device is not readily available in Multisim library. So, I downloaded the SPICE netlist code for it from Analog Devices. I tried to make a component in Multisim using this code. But I am encountering an error (It was also commented in the code that it will work only for ADISimPE). But I need the simulation to be done in Multisim. I am attaching the code below. Please suggest how I can make ADA2200 model in Multisim.
Any help would be very much appreciated!
  • ada2200.txt
Don't you think it were helpful to show us the error message?
That's most likely because the model uses some special functions or models only available in that simulator. If Multisim doesn't support these functions oder models, youÄll have a hard time adapting the model to multisim. And if you manage to get it simulating without indicating errors, how are you going to verify that the adapted model is an acceptable representation for the chip and the simulation results are reliable?
My guess is that this is a dead end.
