Trouble identifying component
I'm repairing a Denon DRA-375RD reciever, and have identified the
faulty part. Problem is, I'm not exactly sure *what* it is. It's in a
2-lead TO-92 package, connected in series with one of the power
transformer secondaries. I'm guessing it's a resettable fuse. It's
electrically open, and carefully bridging it with some resistance makes
the set jump to life. Seems like the circuitry wants to pull a little
over 200mA through it.
The component silk-screen ID is PR401, and the only markings on the
package is:
N25
H
Maybe the "25" means 250mA trip? Anyone have some information? Thanks
in advance.
F
frontline@nospam
No reset if value is exceeded, fuse yes different faster.
I am surprised to see one used at the transformer secondary they are
rated at 50V
designed to protect ICs but could work well for that
transformer/circuit or maybe safety critical part?
Jeff
Michael A. Terrell
So do they reset themselves, or are they just a fuse, essentially? I
can't quite tell from the datasheets.
One time only, no reset. Basically, they are fuses in a plastic case
that can be machine stuffed to lower assembly cost, and have the added
benefit that they keep the end user from replacing the fuse.
