Hello All..
I currently have a 80DC 10A carling / bluesea breaker that I use to engage / protect / disengage the PV side of my solar array.
I am looking to add 3 more panels so my PV DC voltage would rise to at least 112.5V DC (each module is 22.5V and with my controller they run in series). Therefore I need to find an ~120V DC, 10A breaker that I can use in a similar configuration. Open to other solutions as well but keep in mind: 1. Wiring in parallel is NOT an option in my application; 2. I want to avoid using a switch and a fuse.
This is my current form factor and the less modification required, the better. Although I'm more than willing to buy a different PVC box for it and modify it to fit as needed.
Thanks in advance.
Thanks in advance.
