Below is the new way of dimming mains LED bulbs with a wall dimmer.
No more triacs for LEDs.
When you push the button on the wall dimmer, it "cuts out" a mains half cycle at the zero crossings, and the bulb circuit interprets this as "dimming required" and then it either dims the bulb down by a bit, or dims it up by a bit.
Triac dimmers must be consigned to the museums.....there sudden on-switching just resonates with the emi filter of the led bulb......the emi filter of the led bulb needs damping due to the triac dimmer, and bleeder circuits are needed.....also, not one single dimmable led bulb on earth is properly dimmable with every triac dimmer on the market.
