What is the easiest way to generate this pulse from a microcontroller running at 3v3? I have IO pins and PWMs available.
https://en.wikipedia.org/wiki/Tri-level_sync
I haven't dealt with negative voltages before, and I'm not that familiar with analogue electronics (other than simple opamp circuits). My first instinct is to generate -3v3 (somehow?) then use 2 or 3 microcontroller pins to switch 2/3 mosfets or transistors with resistors dividing voltage, but I do wonder if there's a better/ simpler way.
It doesn't seem possible/appropriate to create a virtual ground unfortunately, as the composite signals go out over BNC using chassis ground.
