Hi my name is Luca, I'm a Italian boy, I have one problem with Motor control board (mcb),
the problem is:
after connected the mcb with all cable, I press the start button and nothing happens, motor doesn't start, I have change the IGBT, but nothing has changed,
I've seen beside to main chip one red led (error led) switched on (circled in blue in the picture), I made some measurements on the
HCPL-320 (inside the orange circle)
pin 1 = 0 (Not used)
pin 2 = 3,28V
pin 3 = 2,25V
pin 4 = 0 (Not used)
pin 5 = 0,57V
pin 6 = 0,58V
pin 7 = 0,57V
pin 8 = 13,58V
used the M- (negative motor connector) for ground.
you have any idea? how can I test it?
I have attached a picture of the mcb
the problem is:
pin 2 = 3,28V
pin 3 = 2,25V
pin 5 = 0,57V
pin 6 = 0,58V
pin 7 = 0,57V
pin 8 = 13,58V
