N_Cook
No DC motor control
15V and Sig LEDs on but no Gate or HV bus LED.
Bit of a chicken and egg situation.
5V supply also ok
Mains side uses a pair of SCRs driven by a triac opto that has its
driving internal LED biased off, to provide the power DC as distinct
from minor supply that is present.
Main control is some custom uC.
DC side uses a powerFET to control the motor .
It seems that if there is no gate signal to the MOC opto so there is not
any rectified HV dc for the powerFET , or could the Power|FET be non
functional to some low power test setup and the uC locks out.
Will remove the powerFET and check out of circuit , but at this stage
that seems the limit of any further fault finding. Even applying some
sort DC I asume the uC will lock out anyway, or the uC is corrupt of
course, either way no further forward
5V supply also ok
