Transparent Electronic Objects....
Possible yet? - eg a transparent (well almost by that you see to the other side and out) object like a small diamond, dice, earring size, keyring size, to produce some sort light and activates when dark.....
for example, a diamond (shaped) earring, inside the material is laced with OLED's, weaven into the sides of the diamond could be a transparent (lets some light through) solar panels that could charge minute super capacitors? .. when it senses it goes dark the diamond begins to sparkle at night....
same could be applied to other transparent items.. but jewelry i think could be quite profitable in the future if they can produce enough current to power both the IC (not so much an issue really) the challenge would be to generate enough light....
