Transitor help required Pls!
SME
Hello Group
I wish to reverse the logic from a parallel port output using transistors.
So when the output is high the line into the transistor is high
For example :-
Printport
Collector 12V
Base|/
D0 -----|
Emitter
---------Gnd
As I understand it the above circuit when D0 is high (+5V) will sink the
collector bring the 12V input to Low (I understand there should be resisters
in the above circuit etc etc)
As mentioned above I which to have a circuit that when D0 is High the 12V
input is High and when D0 is Low it pulls the 12V input Low.
TIA
Steve.
Roy J. Tellason
SME said:
Hello Group
For example :-
Printport
Collector 12V
Base|/
D0 -----|
Emitter
---------Gnd
TIA
Steve.
Use a PNP transistor with the collector and emitter connections the reverse of
what you've shown here.
F
Fritz Schlunder
I don't think that will work. He needs level shifting from the 5V parallel
port logic levels to 12V, but he doesn't want the signal inverted.
A PNP with 12V at the emitter and 5V or 0V at the base (through a resistor)
will never turn off.
Depending upon your requirements it might be possible to use some device
like the 7407 to perform this function, however the 7407 does need a 5V
supply as well (that ideally should be of equal to or slightly larger
magnitude than the 0-5V swing of your parallel port). Datasheet at:
http://www.fairchildsemi.com/ds/DM/DM7407.pdf
Alternatively you can use two of those single transistor inverters in series
so the signal is no longer inverted.
Ban
SME wrote:
|| Hello Group
|| transistors. So when the output is high the line into the transistor
|| is high
view with fixed font:
+5V
2k2-10k| |
| open collector
+-----+ o
1.2V-5V CMOS | | |
___ |/ | |/
o-|___|--|2N3904 +---|2N3904
10k |> |>
GND GND
created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
ciao Ban
