Transistor Biasing
Hello,
I'm trying to give a voltage Vb1 and Vb2 in the figure. What circuit topology do I have to use for this?
Thank You,
BlackMelon
Huh?
Any voltage source will do, even a simple resistive divider as the load by the gates is negligible to non-present.
Could you detail your idea a bit more?
Huh?
I am trying to design an op-amp with specifications shown in the pdf file. I can use any topologies I want. But I am allowed to use only one voltage source. Is there any techniques to bias that point?
PS. I think using voltage dividers might get me in trouble after this. Because I have to play with (W/L) ratio to have a specified gain, forcing me to change the resistors in the dividers for new Vgs too. Do you think so? Or is this already the easiest way to do?
  • EECT 6326 Spring 2017 Project.pdf
You could use a MOSFET based voltage reference. But that's probably cracking a nut with a sledgehammer. The accuracy of a resistive divider is probably sufficient in this application.
If you need to change VGS for whatever reason, any circuit you use wiil have to be adjusted, be it a resistive divider or a voltage reference circuit.
When you build the resistors from MOSFETs, you can scale them together with the other MOSFETs, that may (or may not - I'm not deep into your circuit) help lessen the workload.
