Hey Folks,
I need to design a broadband TIA for photo current amplification.
I am using a LMH6629.
I simulated the circuit in Tina-TI an it is working pretty well for a feedback resistor of 330Ohm and a feedback cap of 4pf and a signal of 10MHz.
However the simulation is showing oscillation if I increase the cap to something above 20pf. In my opinion it should be stable for higher caps and only start oscillating if the cap is to small.
However, I developed the board and now it is oscillating at 1.2 GHz with a perfect sine, even without a signal applied!
This oscillation is nearly independent of the feedback cap. I tried form 1pf up to 10pf.
Only if the cap is missing totally (still around 2pf from resistor) the oscillation is getting worth.
So, I think it has nothing to do with the feedback cap but some other issue.
I really have no ideas left..
Schematic: http://imageshack.us/a/img211/617/schematic.png
Board-top: http://imageshack.us/a/img585/4955/boardtop.png
Board-bottom: http://imageshack.us/a/img822/2739/boardbottom.png
Cheers,
Julian Arnold
Cheers,
Julian Arnold
