Hey All,
I was hoping someone could help me.
I've designed/built a 230VAC to 30VDC power supply for a client of mine. Its rated to 2Amps constant with a Peak of 30Amps for 100ms(max).
(Its a AC-DC PSU that allows for a high inrush)
At the last minute they've asked for Transient Voltage Suppression protection... e.g. to protect their sensitive down stream equipment from spikes etc from my unit.
I've found this one on RS.. that I'm going to put in Parallel with my output terminals.. e.g. put a lead in to the + terminal and the other in to the - terminal: http://uk.rs-online.com/web/p/products/6997950/?searchTerm=699-7950
Does this look OK for my normal running spec of 30VDC, 2Amps continuous, 30Amps peak? I've chosen this as the systems built... so this is the easiest way I'm thinking.
Thanks in advance,
Alka
Thanks in advance,
Alka
