Terry said:
oops, Vishay had best remove the numerous product lines they have,
closely followed by coilcraft.
Philips (or whoever they became) make an Integrated Inductive Component
(IIC) that may also do the trick.
Cheers
Terry
Looking at your suggestions I found that Coilcraft does have a good
assortment of transformers, for example these:
http://www.coilcraft.com/pdfs/lm258x.pdf
http://www.coilcraft.com/pdfs/ifly0012.pdf
http://www.coilcraft.com/pdfs/a9967.pdf
I will have to look closely at them to see if any can be made to work,
and whether they can be obtained without a lot of hassle. I don't see
any of them listed using findpart.com , so that's not so good, could be
that you have to get personal with sales folks. ($$$).
This afternoon I spent some time working on my supply, using an old
board of mine (it uses a difficult-to-obtain custom flyback
transformer), and was able to get it working a little differently than
it did in its original +/-14V output configuration.
Some results:
Input (feeding the UCC PWM chip) : +17V through a 402 Ohm resistor. The
PWM chip and the FET together only draw 9.4mA!
Input (feeding the transformer) : +43V
Output (pos) : +56.2V
Output (neg) : -56.9V
That's today's set up, it will probably change.
The freq of the PWM is 57kHz. I find that PWM freq isn't too critical.
That's one thing nice about closed-loop controllers, they will work
reasonably well over a broad range of f, if you don't have tight req'ts.
I don't.
I'm getting a nice waveform on the current sense line that shows current
ramping up to about 1.36V during a 1.28us interval (while the FET is
on). I thought it should turn off at 1V, but maybe not. My current
sense resistor is 1.05 Ohms. So let's see, that would be peak current,
ipk = 1.36V/1.05 Ohm = 1.42A.
Let's assume that the current waveform is flat, rather than a ramp,
just to make things easier to calculate and to allow some slop for worst
case conditions. So current being drawn from the 43V supply is 1.42A
but only during the time 1.28 us interval (out of the 17.5 us PWM
period), or about 7.3%. So the worst case total power into the
transformer is about (43V * 1.42A) * 7.3% = 2.15W. That's not bad, and
that's about how hot things seem. Just noticeably warm to the touch.
OK. The "application" circuit that uses this draws about 4mA * (56V *
2) roughly, or about 448mW. So this supply will work pretty well, and
it does. I tried it out during heavy usage of the "application" and
found that the regulated +56.2V rail holds together very well, with <
50mV of noise. The unregulated negative rail does sag a little, sagging
toward 0 by about 0.5V. So that's not so good, but not a crisis.
One good thing is that the PWM isn't creating noise for my
"application", although it's probably radiating EMI big time. I have it
wired in using various 6" to 18" wires, but both boards (the PWM board
and the "application" board) have sweet ground planes.
Thanks to all,
mw
