Could some electronics guru please shed some light on
this. I am helping a colleague of mine wind a step down
transformer, as a weekend project. We have done all the
calculations, The secondary is center tapped, and my
understanding is that a "pig-tail" has to be created,
which serves as the center tap. The secondary coil
is made of two coils, such that the end terminal of
one coil is attached to the start terminal of the next
coil, -- the "end-start" connection being the center
tap. Is this correct ? Obviously the two coils making
up the secondary must have the same number of turns.
But the question is: suppose the output is 9 - 0 - 9
i.e., +/- 9 Volts with a center tap, for output of 18
Volts. Now would each secondary coil have the total
number of windings for 9 Volts ?
All hints. suggestions would be greatly appreciated.
Thanks in advance for your help.
