G
Guy Paddock
I have a 110v to 25v step-down transformer that I'm trying to have drive an
electromagnetic coil. The original coil this transformer drove was rated for
4 amps and 25 volts. My digital multimeter tells me that the transformer
itself puts out around 27-28 volts, actually. Anyways, I am building the new
coil myself. I have already wound it and measured its impedance. According
to the original rating, the original electromagnetic coil should have had an
impedance of 6.25 ohms. My coil, at the moment, has an impedance of about 8
ohms. My coil will be applied differently than the original coil however; I
need mine to repell something, not just attract it, so I got a 4 amp, 50PIV
Full-Wave Bridge Rectifier at RadioShack and connected it between the
transformer and the coil. Currently, the transformer powers the coil as
required, with specific magnetic poles, and it is capable of repelling other
magnets, but it only functions for a short time (5-10 minutes). During this
time, the transformer gets very hot, and the coil gets a bit warm as well.
My question is this: shouldn't the fact that my coil has a higher impedance
mean that there should be LESS of a load on the transformer? If the first
coil had a 4 amp draw, and had an impedance of 6.25 ohms, then mine, with an
8 ohm impedance, should only have a draw of 3.125 amps (at rated voltage).
If this is so, why am I experiencing a heat issue?
TIA
--Guy
TIA
--Guy
