"Javier Perez" bravely wrote to "All" (06 Jul 04 04:11:48)
--- on the heady topic of "Transformer Hum"
JP> From: "Javier Perez" <
[email protected]>
JP> Why does ballast transformer hum? what is actually moving inside it to
JP> make it hum? I wonder
It is an effect called magnetostriction. Every time the magnetic field
reverses the atoms in the metal vibrate away from each other and then
closer again. On a long piece of metal as in a transformer this may
only be a difference of 1 micron but at 120Hz it is easily heard. The
cure is to mount the transformer on rubber isolators and screw all the
laminations down tight. There will always be residual hum.
A*s*i*m*o*v
.... 'Keep the smoke inside.' -- 1st Rule of Electronics.
