The output is 65W. Does the charger specify how many watts on the
input side or maybe how much current it consumes on 120V?
If it does specify the current then: Power (Watts=Volts *Amps) and that
should tell you the minimum power your transformer should be able to handle.
If nothing is specified for the input side, then I would estimate the
efficiency of the charger to be at worst 75%. With this approximation, the
input power should roughly be about 65W/0.75=87W. A transformer between 85W
and 100W should be fine. The power for 120V or 240V will still be the same.
The fundamental difference is that current is halved at 240V.
One more thing to worry about when a transformer powers anything with a
rectifier if it also has a filter capacitor: The waveform of the current
drawn by the device. The RMS current can be higher than that of a
resistive load drawing the same amount of power and a sinewave current
waveform - sometimes a lot higher. The RMS current is what will heat up
transformer windings.
Try putting a low value resistor in series with the input of the
charger, and looking at the current waveform on an oscilloscope. Draw it
on graph paper and calculate an approximated RMS value.
Or, you may be able to find an automotive lamp that, when placed in
series with the input of the charger, glows without dropping a lot of
voltage nor burning out. Find out how much current it takes to make the
lamp glow the same way, and that's the RMS current drawn by the charger.
Multiply RMS current by voltage, and that's what the transformer has to be
rated for (often in volt-amps rather than watts).
- Don Klipstein (
[email protected])
