Curtis:
Here are some tips on a related model which may help you.
Toshiba TP55G60 PTV instant-shut down,fish eye,fix]
This submitted from a fellow shop: shut down at turn on. Being careful
not to burn a line across CRT's, He unplugged P812 (3 pin conn at
front)
defeating shutdown.When he saw a line appear (no vertical) he unplugged
set.This at least directed him to a specific area. At our suggestion he
ordered and replaced the two convergence IC's both STK 392-110. This
helped.Now he gets picture with a "fish-eye" pattern to the display.Now
replaced the vert output IC "Q301" (LA7833S) and open resistor R327
(3.3
ohm). Fixed.
QUESTION NO. P710-8: Toshiba TP55G60 projection is dead. Relay clicks
on and immediately clicks off. Power LED blinks. All standby voltages
look good. Can hear high voltage come on and die. Varying the input
voltage using a variac was of no help. Relay cycles at about 80 - 90
volts. Heard a snap ( similar to a cap discharging) and the set
started working the next time it was turned on. Power cycled twice and
set continued to work. Shut off the set and turned it back on a coupe
of hours later and the set was dead like before. Waited 10 minutes and
turned on the set. Again heard a snap and the set started working.
Shut the set off and turned it back on - set dead again as before with
relay clicking and momentary presence of high voltage. Hv regulator is
Q483 - IC TA755585.
The flyback is arcing to the core. Replace it before you cause
extensive damage.
I would steer towards the convergence IC's first. Look for bad
connections
where the boards plug in. That blinking light only eliminates about 2
things. Unplugged and working ok.
believe this set has a protect IC "IC Z801" near the front edge of the
chassis that monintors a few inputs from different circuits. Start by
finding
out which input is triggering the protect IC. I had one that the gate
input
pin (pin 14 on IC Z801) was going high, should be 0v if OK. This set
would get
HV then shutdown imediately and HV would bleed off. Relay would click
on and
back off very quickly. The problem was R347 on what is called the "DPC"
board
had changed in value from 180K to 413K. Was a tough one to find. The
DPC
board stands up on the mother board. Hope this helps.
You will need service manual to follow these steps I use for
troubleshooting these.
1. Pull the 130v line fuse and see if the power supply comes up and
regulates at 130 volts.
If it is then the power supply is 99% for sure ok. Reinstall the
fuse.
2. Ground the positive of c474 on the protect module, per the service
manual.
This will rule it out if the set comes up properly. Unground the
capacitor.
3. On the convergence board you will find a 3 pin plug, on of them is
protect line, pull the plug and remove the protect wire. If the set
comes up you have a failure in the convergence circuit. If it does come
up and stay up, some resistors may start to burn on the convergence
board,
unplug the tv before they go up in smoke.
4. Physically pull all the yokes off the picture tubes and make sure
they
are not burnt, if one of them is, that crt probably is also damaged.
VERY
COMMON. If you need to replace the crt, make sure you order the high
voltage lead and high voltage silicon from Toshiba. Affix the lead to
the
tube and wait 2 full days before putting in the set and powering up. It
must be 100% cured before appplying the high voltage.
5. Pull the DPC board and unsolder the protect line. This can be risky
so
be prepared to unplug the tv ASAP. Have seen a 180k resistor increase
in
value and cause dead/ intermittent dead set problems.
6. Pull all the high voltage wires to the crt's out of the hv block. If
set runs, install one at a time with the set off to find which crt is
bad.
7. As a last resort, ground the anode of each of the remaining diodes
on
the protect line, of course with the high voltage leads to the crt's
disconnected. To find which circuit has the problem.
Unplug all 3 convergence yokes and see if the set will come on with pix
and
sound. The pix will be there but with no geometric correction. if it
does
come on then troubleshoot the convergence circuit, probably the STK
outputs
There are 37 distinct protect circuits that can cause it to be dead in
the
manner you described.
Does it have separate digital convergence yokes?
If it does, try unplugging the digital conv connectors one
at a time and try to power up the set in between.
There are lots of shut downs not related to the lamps.
This PTV will shut down at once,can hear the HV come up beforehand.Then
the power LED blinks. Tried unsoldering the STK convergence IC's incase
that was shorted,also unplugged the HV splitter,still shuts down.
Phil check the audio output IC-usually shorts the 26VDC power supply
Robert McPherson
Louisville, KY
(502) 367-9324
