F
flood
Having an extremely hard time finding a part number for a module for
Toshiba CF36H50. I am too cheap to go to an authorized dealer (plu
they are at least 2 hours away and from what I can tell it will cost m
$200 just to get it looked at). The tv is probably only worth abou
$100.
Basically the tv goes into some sort of screen test mode. Rotate
different screen resolutions/formats/colors.
However, in service mode the tv works fine (other than no sound). I ru
the self diagnostic it shows the following info:
Part No: 23906358
Power: 000
Bus Line: NG
Bus Cont: NG H002
Block: UV V1 QV01 QV01S
By no means am I a repair expert but I assume the Part No. is the I
chip it is running the diagnostic on and the H002 is the modul
indicating a fault. Problem is that H002 is only mentioned in th
service mode adjustment section - it is not listed in the parts lis
section - nor is it on any of the board diagrams. I also cannot fin
the label on the board visually (I can find H001 - the tuner - but no
H002). I can find the part number for other Toshiba models but not th
CF36H50 - the parts distributors tell me it is probably different.
Can anyone help me on what this part might look like (so I can identif
it on the main board and get the part number off it) or know of a way t
determine the part number? I have contacted Toshiba and they of cours
were no help.
I really don't want to trash the tv since it still accepts inputs an
still works in service mode.
Thanks for any help you can provide
$100.
Part No: 23906358
Power: 000
Bus Line: NG
Bus Cont: NG H002
were no help.
