topology suggestions for 3.5kW batt charger?
Tesseract
Greetings all - just found this site while searching for "boost pfc" and
noticed that Winfield Hill has posted here before so I figure the site can't
be all that bad ;)
I'm just throwing this out as a sort of curiosity-type question. I have
designed quite a few switchmode power supplies over the years but nothing
even approaching this power level (600W is the previous maximum). A friend of
a friend has one of 492 electric chevy S-10 pickups, and the onboard charger
has lost its magic smoke. Frankly, the design of this charger/motor drive
pretty much blows, ihmo, so I'm toying around with the idea of whipping up
something new. "Toying" because there is little financial motivation for
doing this. However, it is an interesting project and that is motivation
enough, sometimes.
There are two banks of batteries in the pack, each containing 26 12V/42Ah
batteries. The manufacturer, Genesis, recommends charging them at the 0.4C
rate up to a maximum of 2.4V/cell (with -20mV/C of compensation). As this
comes out to a rather onerous 6.3kW, I'll either have to go with a less-
ambitious charge rate or force the guy to unplug the range every time he
needs to plug in (or, of course, have a dedicated 40A. circuit installed). As
of now he does have a 240V/20A circuit for this purpose which, if we adhere
to the NEC, gives us *just* enough continuous amperage to charge each bank at
0.25C (10.5A) . This means both banks can be sequentially charged in about 8
hours, which is tolerable.
A linear and/or design using 60Hz magnetics is totally out of the question -
you won't be able to move the thing around without a forklift. The next
simplest thing I can imagine, then, is to use the output of a boost PFC more
or less directly. This has some serious safety issues, but it ain't like I'm
going to be submitting it for UL approval any time soon. So, these are the
various factors/ideas I am contemplating:
quasi-resonant (soft) switching; ZVS or ZCS?
IGBTs or advanced MOSFETs
Boost PFC + full-bridge or some combo to provide isolation
Current mode control is a natural, here. Voltage regulation needs to be
accurate but there's no need for a lot of loop bandwidth (ie - fast transient
response not required). Ideas welcome!
-Jeff
MooseFET
be all that bad ;)
enough, sometimes.
batteries.
In other words, we need a voltage of about 26*24 = 624, or so, as a
maximum?
240 * sqrt(2) = ABOUT 340V
As a result, we need to about double the voltage. This smells like a
transformer based design not a simple booster.
Just for fun I'll suggest this:
L1 T1 ( !!- ! ---
----(((((---------+ G1-!!- ! ---
( !!--[sense]-GND ! !
( ! GND
G2-!!-
!!--[sense]-GND
At the wareform peak, the G1 and G2 are running almost as a squareware
converter with only a small dead time when both are off.
When both devices are off, the L1 voltage springs up to the battery
voltage to ramp down the current in L1. When either is on (Vin-Vbat/
2) ramps the current up. In this way, near the peak, L1 is working to
buck the input.
As you come off the peak of the mains AC, the duty cycle of the G1 and
G2 increases. At some point, their conduction overlaps. When this
happens, L1 begins to boost because the center tap pulses to zero
volts while both are on.
The core of L1 never has to store huge amounts of energy. The core of
T1 also isn't storing lots of energy because it is working as a
transfomer.
L1 and T1 can be merged into a single core if you are willing to do
some creative winding.
Phil Allison
"Tesseract"
of
charger
enough, sometimes.
As
adhere
at
8
question -
** Not true at all.
The next
more
I'm
** Ok - here is your *simplest* solution.
Use a 240 volt to 40 volt transformer, rated at say 25 amps to boost the AC
supply to 280 volts rms.
A 40 amp metal bridge on that will give 400 volt peaks at 100Hz.
400/26 =15.4 volts a piece = just about right for end of charge.
Install a DC amp meter ( say 30 amp FS) in series with the battery bank.
Use a 1kW Variac to control the input to the boost transformer so you can
adjust the charge rate to a nice number like 15 amps.
Keep your fingers off the damn batteries ( ie wear gloves) and keep all
spectators at bay with a safety fence around the vehicle !!!!
........ Phil
colin
can't
be all that bad ;)
of
charger
enough, sometimes.
As
adhere
at
8
question -
more
I'm
transient
-Jeff
how about a dozen PC power supplies ?
just modify them to work in current limit mode.
they should then share the laod ok.
Colin =^.^=
W
Wimpie
be all that bad ;)
enough, sometimes.
-Jeff
Hello Jeff,
When a switching topology is a mandatory, mi first thoughts go to a
full bridge forward converter with zero voltage switching where the
current limit is determined by the leakage inductance of the
transformer (probably a very large set of U cores). This is inherently
short circuit proof and you have plenty of time to shut it down. The
voltage waveform at the bridge is trapezoidal. dV/dt at the switches
is limited by the external capacitors.
Instead of one unit, I would use (depending on components available) 2
or three units. In that case, main charging is done by (for example) 3
units in parallel. As the voltage reaching final level, one or two
units are switched of. When you can make one, you can also make three
units.
Main advantage for a full bridge circuit is the ripple current in both
the primary rectifier and secondary rectifier. There is also efficient
utilization of the semiconductors. High dI/dt is avoided because of
the leakage inductance of the transformer. The transformer design is
somewhat tricky. You might use a separate coil for dI/dt limiting.
Because of the required large sized magnetics, you are limited in
maximum operating frequency because of risk on bad flux distribution
due to field propagation issues inside the magnetics.
You can drive the IGBT's or MOSFETs with one transformer (with 4
secondary windings).
Best regards,
Wim
PA3DJS
www.tetech.nl
Tesseract via ElectronicsKB.com
Thanks for the excellent replies, everyone.
maximum?
Sorry - I wasn't clear about that: it is, in fact, two independent 312V nom.
battery banks that, as far as my "eyeball" reverse engineering reveals, are
selected via contactors. I can only *guess* at the reasoning behind this, but
I imagine thermal management is a factor...
L1 T1 ( !!- ! ---
( ! GND
G2-!!-
!!--[sense]-GND
This is a very interesting idea, Moosefet. It sort of looks like half of a
phase-shifted bridge. L1 makes it inherently a current-fed topology which is,
of course, immune to short circuits. Any references, or at least a "proper
name" would be most appreciated.
-Jeff
An even simpler but similar idea is my "backup" solution. Specifically, I
would connect a 120V input Variac to one leg and neutral of the 240V line
then take the output from the Variac tap and the other leg of the 240V line
to get anywhere from 240 to 360Vrms. Add a bridge, a good chunk of
capacitance, season to taste and voilla, a cheap, quick and dirty battery
charger. The filter capacitance is a nod towards battery life - they
apparently really hate pulsating DC... Big downside here is the terrible
power factor which limits the actual charging current that can be delivered
to the batteries before tripping the breaker.
Colin - you're idea is nuts, but not totally out of the question. If the PC
power supplies have PFC and use current-mode control then this is plausible.
No PFC and the same problem as above creeps in. Voltage mode control instead
of current mode and paralleling is a dicey situation no matter what. I doubt
any halfway reliable PC power supply made today uses voltage mode control,
but you never know what an OEM will stoop to when the very depths of the
price/performance ratio are trolled.
-Jeff
I agree completely - when you need more than about 300-400W of *isolated*
power then the full bridge topology, in any of its many variants, is the way
to go. Setting aside line isolation considerations for the moment, though, I
don't see any advantage over a much more simpler boost PFC, especially if
designed to operate in quasi- or fully resonant modes.
Transformer design is *always* tricky, especially with regards to managing
leakage inductance. Current-fed might be the way to go here, but I suspect
that (quasi-)resonant operation will still give you the best combination of
low-emi and switching stress and excellent current-limiting response.
Once again, if I was going to design the charger for approval then full-
bridge would be the way to go, and in order to make maximum use of the
available RMS current PFC circuit is pertty much mandatory. In fact, if you
eliminate the bulk filter capacitor from the output of a boost PFC then feed
a full bridge you automatically get short-circuit-proof current-fed mode,
IIRC.
Excellent comments, though, Wim.
-Jeff
Phil Allison
"Tesseract.... "
** Err - did you want ideas supplied from others OR others to verbally
masturbate over your insane ones ?
Just be upfront, pal - it saves everyone lotsa time .......
Specifically, I
line
** If you have 60 Hz, 3 phase, 240 volts available - you failed to tell
us.
BTW the phase to phase voltage is 415 - not 360.
charger.
** Dirtier than Dirty Harry
How lucky do you feel - punk ??
This man is ON the edge ....
......... Phil
Oh come on - it's a *given* that you already *have* lotsa time or you
wouldn't be reading (and replying) to the posts here.
Actually, I really want ideas from others. No pud-pulling necessary.
us.
Thanks for pointing this out - helping identify stupid, fireball-forming
mistakes *before* I make them is the whole point of posting. This *is*
residential 240V, so your implying that 3ph. would be needed caused me to go
back and actually sketch out a schematic. Once I did that the fatal flaws in
my backup plan became obvious. I should've kept TANSTAAFL in mind...
Now I agree that your suggestion - wiring a transformer in standard boost
configuration - makes the most sense as the simplest solution. Unfortunately,
I don't have any 240V Variacs so I may have to go with a voltage doubler.
Fortunately, I do have two 6,000uF/400V caps that will serve nicely here.
Well, once I make sure the dielectric is fully formed on them as they haven't
seen voltage in quite a while.
-Jeff
colin
line
delivered
PC
plausible.
instead
doubt
Yeah I hadnt given it a thought that it would be high voltage,
was thinking of car battery charger voltages lol.
I did say to modify them to current mode,
becuase most PC supplies go into burp mode if they sense overcurrent,
rather than refering to the PWM topology.
I doubt if they have PFC though,
wich i gues is needed for the full power.
however for the high voltage parallel isnt desirable.
and series conection is fraught with problems.
maybe if you put one psu acros each 1 x 12v bank if you had access to mid
points.
At least PC PSUs are abundant in landfill sites.
its quite easy to rewind some of them so they have just one very high power
output,
and strip the unused components.
as was said elsewhere multiple phases would make things easier,
and add some backup.
boost PFC followed by resorvoir cap, followed by fwd resonant phase shifting
full bridge,
folowed by full wave rectifier (posibly synchronous if you want to be fancy)
+ LC filter.
but you can go through a LOT of components getting a high power SMPS design
debuged.
also the output voltage is still so high as to be lethal,
so it needs to be heavily protected from careless fingers etc,
so why bother with isolation wich is 80% of the work ?
just have a step down converter after the resorvoir cap wich does the
current/voltage limiting.
Colin =^.^=
Phil Allison
"Tesseract via ElectronicsKB.com"
** Wrong answer, pal - that one labels you as a troll for sure.
The saved time alluded to would be that time span between one merely
suspecting YOU were yet another totally mad troll and being completely
certain of it.
go
in
** Not a familiar acronym to me....
** You have now acquired near genius status.
Asking for exact details of my proposed anti-spectator HV electrical safety
fence would have resulted in mucho bonus points.
Unfortunately,
** Sloppy impedance cap dominated regulation = baaaaaaaaddddddd !!!
haven't
** Those spectators need to be wearing safety goggles and steel lined flack
jackets.
Bits of flying electro & lead acid battery are significant shrapnel.
........ Phil
MooseFET
maximum?
L1 T1 ( !!- ! ---
( ! GND
G2-!!-
!!--[sense]-GND
How about calling it "KenSmith's Idea"?
This circuit is certainly not immune to a short. There is a DC path
from the Vin to the Vout so short circuit currents have a path through
even with the transistors off.
It is a "current fed" design in that the L1 limits the current rise.
Basically it is a current fed forward converter where the transformer
in an autotransformers. The sliding between the overlapping and non-
overlaping conduction requires a bit of custom controller design.
V
Vladimir Vassilevsky
be all that bad ;)
enough, sometimes.
I was involved in the design of the 10kWt subwoofer amplifier (powered
from the primary power source of 14.4V). Actually, I designed the
DSP/PWM controller for it; the power part was designed by the other guy.
There is absolutely nothing fancy about the topology: a classic MOSFET
push-pull voltage mode buck running at 24kHz. The magnetics for it was
quite a challenge. The size of the whole thing is 50x30x10cm. It works
just fine. For the battery charger, you will need to output the
regulated current rather then voltage; it should not be a problem.
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
W
Wimpie
IIRC.
-Jeff
Hi Jeff,
I forgot Power Factor Correction.
You may design an active power factor correction circuitry. Your
application probably doesn't require power factor of 0.99. When a
power factor of about 0.9 is sufficient, you may use the CLC passive
topology where the first Capacitor is at the AC side of the bridge,
the inductor is between the bridge and the DC output storage
capacitor. http://lib.tkk.fi/Diss/2001/isbn9512257351/isbn9512257351.pdf.
This document describes various passive and active power factor
topologies.
I think when I was in your position; I would use the passive PFC and
fully concentrate on the zero voltage full bridge design with leakage
inductance. I like this thing because you don't have to measure the
momentary current, the transformer may have large leakage inductance
(so safety insulation is easy to obtain) and there is low dV/dt and DI/
dt (radiated emission).
Off course he disadvantage for passive PFC is the bulky L and Mains
capacitor. Maybe you can get some inspiration from the document. I do
not have experience with zero voltage or zero current switching PFC.
Best regards,
Wim
PA3DJS
www.tetech.nl
certain of it.
The solution to this seems obvious to me: don't post to this thread.
I'm liking this idea of your's more and more, Colin. I found a 600W PC power
supply with active PFC on eBay for $25, incl. shipping. That's definitely
cheap enough to play around with. Heck, the Litz wire I'll need for the
secondary will probably cost more than the power supply itself!
If an SMPS uses current mode control, though, paralleling two or more
together is trivial, even if Vo is high. I totally agree that no matter what
the control scheme you are asking for trouble when you try to put supplies in
series (dueling feedback loops).
debuged.
That's the truth, and the components that blow up tend to be expensive ones...
This was precisely my reasoning for just going with a straight boost PFC
design.
Thanks for the input - I'm definitely going to try this on one supply even if
the total output from one PC supply isn't enough to make a practical charger
(I need to keep the total charge time for the two banks under 12 hours for it
to be at all practical, which means I need at least 2.6kW). Still, as a quick
and dirty charger it has lots of merit (and it will be isolated, anyway).
-Jeff
Phil Allison
** YOU do not get to contol a thread or any person on a NG - ASSHOLE.
....... Phil
Phil Allison
"Vladimir Vassilevsky"
from the primary power source of 14.4V). Actually, I designed the DSP/PWM
controller for it; the power part was designed by the other guy. There is
absolutely nothing fancy about the topology: a classic MOSFET push-pull
voltage mode buck running at 24kHz. The magnetics for it was quite a
challenge. The size of the whole thing is 50x30x10cm. It works just fine.
For the battery charger, you will need to output the regulated current
** Oh dear - that is very poor advice.
** Explains a lot.
........ Phil
Fair enough. Still, with no prior art to study one would have a lot of pain
and misery to look forward to before getting a new topology working, much
less optimized.
What I meant by this is that a short circuit will not cause immediate
destruction of the switch(es). L1 will saturate, of course, and a circuit
breaker will trip, but once the short is removed and power restored the
circuit should resume operating.
I still think you could probably use half of the outputs of a phase-shifted
full bridge controller IC to manage this topology (eg - UCC3895).
-Jeff
