Hello everyone!
I’ll get to the point as I tend to type a lot, but details are below under my quick main question here.
A while back I acquired a broken Todd Engineering, INC. model PC40B Power Source Battery Charger / Power Supply.
There is one part in here that is blown beyond recognition, the PC Board designation is U1.
Can anyone tell me what the numbers are off this IC chip? It is an 8-pin dip.
Detailed post below:
The chip was actually intact when I first got the supply; I already attempted to repair it & got ahead of myself & forgot to replace U3 which is an LM393. I was pretty sure the 393 was shorted or at least leaky, but it took a few weeks to get the parts in & I forgot where I was at with this thing & did not replace the 393. Needless to say it blew up again & this time took out U1 (which may have been faulty anyhow), & stupid me did not write down the numbers off the chip before hand, I know I looked for a datasheet for the chip originally, but could not find a supplier for it anyway, but I should have wrote it down.
I originally found U2 bad which I replaced with an LR645, the original one was blown apart and from searching the web that is what I found that may have been in there & the pin-out seemed correct, but if U2 is something else please inform me on that as well. I also replaced D13 which is a 15v 1w zener diode as it was shorted, & I was pretty sure U3 an LM393 was bad as well but forgot to replace. I wanted to replace the known bad parts so I could continue troubleshooting, but now I am stuck not knowing what U1 is. This time around it also took out the other U3 which is a CNY17-3 which is located on the vertical PC Board, but fortunately I ordered one of those incase I needed it.
At this point I already replaced everything that I know for sure is bad except U1.
I seen this thread: https://www.electronicspoint.com/rv-power-converter-todd-pc40-insulator-problem-t46674.html
And was hoping someone here could help with this & may be able to tell me what U1 is.
I am not sure if I should post in the other thread or not, I seen a notice that I should post here, so I don’t know. I guess if no one here has one to look inside for me I can always try that thread too?
I would really like to repair this thing if at all possible, if not I can use it for parts, but I really hate parting something out unless it’s really beyond repair.
Thank you all for reading this & for any help you can give!
Take care!
Take care!
