G
Ge0rge Marutz
Hello Gentleman (and ladies?),
My company manufactures an automotive assembly that uses a small 24VDC
motor to pump fluid. We recently went through a round of EMC testing
under SAE J1113-41 guidelines.
To make a long story short our product behaves very well until the
motor turns on. At this point emissions go through the roof. The
product is well above an acceptable limit.
A little background. The PCB and pump motor are housed in a custom
molded plastic enclosure. It is not possible to change the housing at
this time in case you were going to recommend metal. The motor sits on
top of the PCB and is housed in its own plastic pump sub-assembly
(again, cannot change). The circuit board is a 4 layer board with
dedicated power and ground planes. The pump is switched on and off
with a N-channel MOSFET low side drive transistor. Two wires
(approximately 30mm each) go from the circuit board to the pump. I have
1000pf capacitors placed on the PCB from the point of entry of each
wire to the PCB and ground (common mode filters I believe). I also
have a 100nF SMD capacitor placed between the pump motor wire leads at
the point where the wires leave the board. The PCB seems to be immune
to the high levels of RE. We have had no problems even considering the
fact that this noisy pump sits right on top of the PCB. My big concern
is what this motor might do to other electronics. We would like to
meet SAE J-1113 guidelines for at least a region IV device, preferably
region III or higher.
I tried to attenuate RE by connecting the motors metal body to the
ground plane of my PCB. It did not seem to help much.
Do you have any suggestions? Is there something I can do to my
assembly to quiet down RE ( like metalized paint on interior of
housing)? Is there something that can be changed with the pump design
to reduce RE?
Looking for any hints you have to offer.
Thank you,
George
to reduce RE?
Thank you,
George
