I am building a display consisting of a series of seven 5x7 LED dot
matrix displays, butted up against one another. The displays are of
the 0.7" variety (about as small as they come). I will be driving them
with PWM to control brightness, using shift registers to control the 35
horizontal elements, and switching the 7 rows sequentially to paint the
display. The pulse current on each dot is 100ma, and times 35
horizontal dots, that's a potential max of 3.5A.
Problem is, I am trying to keep the board small. The traces required
to handle 3.5A are pretty fat - too fat to allow the close spacing I
need for the project.
Anyone have any tips?
Some ideas....
I could mount the through-hole displays in DIP to SMT adapters and
surface mount them, freeing up the back of the board to route my
traces. Downside is cost and increased complexity, and the board would
be thicker
I can seperate out the segments into 2, 2 and 3 and they'd be 1A, 1A,
1.5A, which I can fit the traces. However now I am faced with routing
three fat traces to each of my power transistors that switch the rows,
and I'd definitely have to increase the board size to accomodate
I can use a 4-layer board... probably the most suitable solution, but
more expensive
I am already putting all my shift registers and microcontroller on a
sub-board, so I've trimmed the components on the display to the bare
minimum.
Any other ideas? Routing this board is driving me nuts!
Thanks!
Corp.
Some ideas....
be thicker
more expensive
minimum.
Thanks!
Corp.
