Hi All,
Hope you guys are doing well.
I have a question on how to energize a timer relay ( this is the timer http://ca.digikey.com/1/1/53823-relay-timer-dpdt-analog-120-240v-h3cr-a-ac100-240-dc100-125.html)
I know how to wire a timer relay, but this is the senario:
I need to have a push botton (normally closed) pressed to reset a circuit in my car, the way i wanna set it up is, to hook up the timer relay with the door switch, so when i open the door, the door switch would power up the timer, and the timer will reset the switch in few minutes. The only issue which i am having at the moment is that, i have connected the timer (-) to the door switch and (+) directly from the battery, so when i open the door it would energize the timer and when i shut the door the timer would loose power! and i am unable to achieve what iam looking for. Need an advice on how to connect the timer to the door switch and would get powered as soon as i open the door and would stay powered when i close the door so it would reset a switch after few minutes?
Thanks,
Yazen
Thanks,
Yazen
