Hi all,
I'm a struggling to do a project in less than 1 week for a charity and wondering if the www can help. I'm a complete electronics/Arduino beginner so please break down any suggestions, thanks!
The challenge:
I need a little water pump to run for 3 seconds with a 10 minute pause completely off the grid 24/7 from a battery. I need the battery to be charged using a solar panel and hold enough storage to run 2 days without sunlight. An Arduino is also needed to change the duration and interval of the pump.
What I know:
The pump requires ~12v @ ~270mA (5W)
and 64.8mAH (for 2 days of operation)
(pump runs for 18s per hour = 0.05h per hour
0.05h x 270mA = 1.35mAH
1.35 x 48hrs = 64.8mAH)
I also need to be able to take the battery on a flight so please recommend a suitable battery for the system (I was thinking maybe the Li-ion 18650? http://www.ebay.co.uk/itm/311727421481?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT).
Pump: http://www.ebay.co.uk/itm/222223864810?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
What is the simplest way to wire & code everything up? (Please also recommend any required components)
Any help is much appreciated!
The challenge:
What I know:
