Time Step too small in EWB
Sharptop
In Electronic Workbench I am getting the error
Output from instrument analysis
TRAN: Timestep too small; time = 0.029452, timestep = 1.25e-015:
trouble with node $20:xu1
doAnalyses: timestep too small
I set the time step manually but still get the error and I do not see a
node $20.
K
Kevin Aylward
This is a node internally in the .subckt model, of probable, u1.
a node $20.
It doesn't matter what you set the minimum time step, this message means
that internally the circuit isn't converging.
There are many reasons for non convergence. Check for floating nodes,
and unrealistic circuit design.
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
W
Winfield Hill
Kevin Aylward wrote...
message means that internally the circuit isn't converging.
floating nodes, and unrealistic circuit design.
Right... e.g., add a bit of G-ohm leakage resistance to ground
on high-Z nodes, add some series resistance for inductors, ditto
for caps (esr) if in a series loop, etc. Mostly it's just stuff
that always exists with real components in real circuits.
Jim Thompson
node $20.
node $20 should be in subcircuit xu1
Make sure you have a ground node, 0 (zero).
Make sure your circuit has realistic impedances... ideal inductors can
ruin your day ;-)
...Jim Thompson
W
Winfield Hill
Jim Thompson wrote...
can ruin your day ;-)
Right. Standard spice inductors have zero resistance, which means
they have infinite Q. Standard spice capacitors also have zero
resistance, which means they have infinite Q. These two components
often occur together (all real inductors have self capacitance, and
real nodes have capacitance to ground, etc.), potentially creating
resonances with infinite Q. How is spice supposed to be able to deal
with that? It's up to the user to create real components, by adding
appropriate lossy resistances.
