Ticking with dustsucker against lamp makes lamp brighter.
Skybuck Flying
Hello,
I have a question for ya:
Why does a lamp start shining brighter after ticking against it with a
dustsucker/vaccuumcleaner ?
Bye,
Skybuck.
P.S.: Now I continue dustsucking :)
Jon Slaughter
Skybuck said:
Hello,
Bye,
Skybuck.
Doesn't your lungs hurt?
Are you bumping into it with your mouth that is causing the filiment to
vibrate?
Skybuck Flying
Define "ticking against it"
Accidently, or deliberate tick with hose against lamp pole...
Doing it repeatedly makes the lamp shine brighter and brigther until it pops
dead.
(Philips lamps)
Bye,
Skybuck ;) :)
Skybuck Flying
Nope, I with my vacuum cleaner ofcourse ! ;) :)
vibrate?
Hose might be doing it. Would vibration in the lamp be bad ?!
Is this a conspiracy by Philips to make the lamps pop when a car/truck
drives by ? ;)
Bye,
Skybuck.
Tim
Maybe you slowly short the turns of the filament with each tap, until it
finally burns up?
- Tim -
Paul E. Schoen
pops dead.
(Philips lamps)
This illustrates the reason for rugged or rough service lamps, which are
used in portable drop lights that might get banged around or experience
shock and vibration from hammering, drilling, etc. Such lamps are built
with more filament supports so the hot filament does not stretch and
eventually break. Mechanical shocks while the filament is incandescent
might cause some turns to short out and thus cause more current and higher
brightness.
Phase out incandescent lamps and use CFLs. Even better are LED lamps, and
they are very rugged and should last just about forever, but I've heard of
some limited lifetime issues, mostly due to phosphor coatings
deteriorating. I don't think that's an issue with white LED clusters that
are composed of red, green and blue. They also have the advantage of being
adjustable for color temperature.
Paul
