Hi all
I have a "Sunpak Auto Zoom 5000 Thyristor Flash", which I have owned literally man-and-boy; I bought it in 1977 with hard saved pocket money and after months of research. In those 40 years it has performed flawlessly with the only issues the need to replace the NiCds from time to time. I know I should dump it, but it's an old friend and I don't want to see it go to land fill just yet if I can fix it.
When working correctly the power output is is ether automatically controlled by an optical sensor system, or manually selected by the user: 1/1; 1/2; 1/4; 1/8 .....1/128 fractions of full power. In the middle of a session of using it last week the power control quietly failed (no magic smoke, etc) and it now only functions at full power.
On taking it apart I can see no obvious burnt or damaged components. I guess the thyristor (in the title of the model name) is used to cut the voltage to the flash tube once the required amount light has been delivered so the fault is associated directly with this component. I am guessing that the thyristor is a pretty robust device and if it had failed maybe there would be no output at all? My initial thought from experience of ageing electronics is that a capacitor in a timing circuit may have failed, but as you can tell I am far from being any expert.
My test and repair kit comprises a soldering iron and digital multimeter. Does anyone have experience of such flash guns? Am I likely to be able to repair my trusty pal (with assistance), or should I just be packing him off to the great flash graveyard?
PS I am aware of the high voltages present in such devices and think I have identified the section to steer clear of, but advice on staying shock-free probably wouldn't go a miss either.
Thanks in advance.
Thanks in advance.
