I captured an output voltage waveform of the three-phase rectifier system. Could anyone help me understand what might be the cause of the little spikes?
Is this supplying any load, or just a 3ph rectifier?
What is the source of the 3ph?
Where are you referencing it to, the wave form is not a normal rectified pattern for 3phase.
The should have a 120deg overlap for every cycle.
M.
It has dc crane and dc led lights on the system. The crane load is on and off. When the led lights are on, the problem exaggerates. I'm trying to figure out the source of the problem, the rectifier or the led driver. The source of the 3ph is from a three-phase ac transformer.
