Hi, let me start by saying I dont know much about electronics, which is why im here!
Im a product designer and im working on a new device. A breif overview of the device is a cabinet that is placed over a radiator to dry clothes in. I want to condense the warm moist air given off by the drying clothes into water, to prevent it from creating mould indoors. This will be essentially a cooling cabinet with a heat sink inside it.
I want to use the heat of the radiator and a thermoelectric generator to produce electricity to then go on to power another Thermo electric plate, making use of its cool side to cool down the cabinet.
Firstly, I know this is an inefficent method, but really want to avoid any external electric input. Secondly, could i literally just connect one TEG up to another?
Im assuming that it gives off an AC and that this would not need to be inverted. If it was an AC i thought that there would be a direct relationship between the heat input and the final cooling output.
Thanks for taking the time to read, I apologise for my electronics illiteracy.
Cheers,
David
Cheers,
David
