I have a temperature control that reads one degree lower than the trigger temperature setting and I'm wondering if there is a method to have the sensor adjustable to calibrate it to the control?
If the trigger is set at 15C it doesn't trigger until it reaches 14C.
Does the one meter of wire add significantly to the resistance of the sensor, would adding or removing wire change the resistance to a point where it affects temperature ?
http://www.ebay.com/itm/400762591095?_trksid=p2060353.m2749.l2648&ssPageName=STRK:MEBIDX:IT
