Hello,
To keep things short and to the point I have installed in my condo an Honeywell digital thermostat that can use remote temperature sensors(which I absolutely need in my case) an it calls for any "20k Ohm curve NTC sensor", the schematic in the manual shows a thermistor with a bridged resistor(unkown value) across the leads. I'm on a very,very small budget and would like get things running with common/available parts, 20k ohm thermistors is not common stock item any where local and ordering online not possible due to shipping costs being way more then parts, I can get 10k Ohm NTC thermistors but unsure if two 10k thermistors in series would produce what I need and unsure what the purpose of the bridged resistor is or how figure out what it's value would be. Basicly I'm asking is it possible to build a 20k Ohm curve NTC temprature sensor from a mix of more common parts?
In advance Thank you to any one who replys with any information
