All,
I am working on a project but am not the most proficient with designing electronic circuit. I'm hoping to bounce this idea off you and see if I'm close to the right idea.
The background is that I want to create a thermally control fan switch for my truck. Right now it had a mechanical fan clutch and I don't like it. I have a couple of fans that draw a lot of CFM, more than sufficient to keep my truck cool.
I would like this to be thermally indexed, meaning the fan will kick on at a certain temperature, but only at 50 or 60% of full power, then increase as the temperature increases up to 100% power. (I want to do this to avoid any unnecessary stress to the alternator as it powers on.) The fans are both 30 amp fans off of a Volvo truck.
My thought is that I will need some sort of thermistor for determining the temperature. I was going to use a simple engine coolant temperature sensor for this.
To control the fan speed, I was thinking a MOSFET would work for pulse width modulation to start the fans. Or would an SG3525 be better?
Really, this is as far as I think I know.
So here are a few questions right out of the gate:
- Do I put a variable resistor in line between the thermistor and PWM to control when the fan kicks on?
- As the temperature decreases, will the fans behavior be the exact opposite of the temperature increasing?
- 30 AMPS is a lot of current. How can I safely pass this current to the fans without burning any of my electronic components up?
If this will work, I have found a schematic that I think will work, but I still wonder how I can do this without burning up my components.
If anyone has any suggestions, I'd appreciate any help or feed back.
